Software Design
Software framework
Software Design Diagram
Business initiation process
Code Explanation
data management
The Storage
class of common.py
is an extension based on Python's built-in dict
class, used to provide thread safe dictionary storage and support loading and saving data from JSON files.
class Storage(dict):
def __init__(self, *args, **kwargs):
super().__init__(*args, **kwargs)
self.__lock__ = Lock()
self.__storage_path__ = None
def __enter__(self):
self.__lock__.acquire()
return self
def __exit__(self, *args, **kwargs):
self.__lock__.release()
def __from_json(self, path):
if self.__storage_path__ is not None:
raise ValueError('storage already init from \"{}\"'.format(self.__storage_path__))
if not ql_fs.path_exists(path):
ql_fs.touch(path, {})
self.update(ql_fs.read_json(path))
def init(self, path):
if path.endswith('.json'):
self.__from_json(path)
raise ValueError('\"{}\" file type not supported'.format(path))
self.__storage_path__ = path
def save(self):
if self.__storage_path__ is None:
raise ValueError('storage path not existed, did you init?')
ql_fs.touch(self.__storage_path__, self)
Service module
Lbs_Service: Provides Lbs data location service
gnss_Service: Provides gnss data location services
Sensor_Service: Provides sensor data detection services
Qth_client: Provides data upload and callback services
The relationship diagram between each service and client is as follows:
Sensor data collection
The SensorService
class of SensorService.py
is a service class used to manage sensor data collection and updates, mainly responsible for initializing I2C channels and multiple sensors (SHTC3, LPS22HB, and TCS34725), and continuously reading temperature, humidity, air pressure, and RGB color values from these sensors. It is also responsible for sending these data to the designated QTH client.
class SensorService(object):
def __init__(self, app=None):
# i2c channel 0
self.i2c_channel0 = I2C(I2C.I2C0, I2C.STANDARD_MODE)
# SHTC3
self.shtc3 = Shtc3(self.i2c_channel0, SHTC3_SLAVE_ADDR)
self.shtc3.init()
# LPS22HB
self.lps22hb = Lps22hb(self.i2c_channel0, LPS22HB_SLAVE_ADDRESS)
self.lps22hb.init()
# TCS34725
self.tcs34725 = Tcs34725(self.i2c_channel0, TCS34725_SLAVE_ADDR)
self.tcs34725.init()
if app is not None:
self.init_app(app)
def __str__(self):
return '{}'.format(type(self).__name__)
def init_app(self, app):
app.register('sensor_service', self)
def load(self):
logger.info('loading {} extension, init sensors will take some seconds'.format(self))
Thread(target=self.start_update).start()
def get_temp1_and_humi(self):
return self.shtc3.getTempAndHumi()
def get_press_and_temp2(self):
return self.lps22hb.getTempAndPressure()
def get_rgb888(self):
rgb888 = self.tcs34725.getRGBValue()
logger.debug("R: {}, G: {}, B: {}".format((rgb888 >> 16) & 0xFF, (rgb888 >> 8) & 0xFF, rgb888 & 0xFF))
r = (rgb888 >> 16) & 0xFF
g = (rgb888 >> 8) & 0xFF
b = rgb888 & 0xFF
return r, g, b
def start_update(self):
prev_temp1 = None
prev_humi = None
prev_press = None
prev_temp2 = None
prev_rgb888 = None
data = {}
temp1, humi = self.shtc3.getTempAndHumi()
logger.debug("temp1: {:0.2f}, humi: {:0.2f}".format(temp1, humi))
if prev_temp1 is None or abs(prev_temp1 - temp1) > 1:
data.update({3: round(temp1, 2)})
prev_temp1 = temp1
if prev_humi is None or abs(prev_humi - humi) > 1:
data.update({4: round(humi, 2)})
prev_humi = humi
except Exception as e:
logger.error("getTempAndHumi error:{}".format(e))
utime.sleep_ms(100)
press, temp2 = self.lps22hb.getTempAndPressure()
logger.debug("press: {:0.2f}, temp2: {:0.2f}".format(press, temp2))
if prev_temp2 is None or abs(prev_temp2 - temp2) > 1:
data.update({5: round(temp2, 2)})
prev_temp2 = temp2
if prev_press is None or abs(prev_press - press) > 1:
data.update({6: round(press, 2)})
prev_press = press
logger.error("getTempAndPressure error:{}".format(e))
utime.sleep_ms(100)
utime.sleep_ms(100)
b = rgb888 & 0xFF
if prev_rgb888 is None:
data.update({7: {1: r, 2: g, 3: b}})
prev_rgb888 = rgb888
prev_r = (prev_rgb888 >> 16) & 0xFF
dr = abs(r - prev_r)
prev_g = (prev_rgb888 >> 8) & 0xFF
dg = abs(g - prev_g)
prev_b = prev_rgb888 & 0xFF
db = abs(b - prev_b)
# 色差超过 150 即认为颜色有变化
if pow(sum((dr*dr, dg*dg, db*db)), 0.5) >= 150:
logger.error("getRGBValue error:{}".format(e))
if data:
with CurrentApp().qth_client:
for _ in range(3):
if CurrentApp().qth_client.sendTsl(1, data):
break
prev_temp1 = None
prev_humi = None
prev_press = None
prev_temp2 = None
prev_rgb888 = None
utime.sleep(1)
QTH platform client
The QthClient
class is a client class used for communicating with the QTH (Quantum Technology Hub) platform. It is responsible for initializing, initiating, and managing connections with the QTH platform, as well as handling various events and callbacks from the platform.
logger = getLogger(__name__)
class QthClient(object):
self.opt_lock = Lock()
if app:
self.init_app(app)
self.opt_lock.acquire()
return self
self.opt_lock.release()
app.register("qth_client", self)
Qth.init()
Qth.setProductInfo(app.config["QTH_PRODUCT_KEY"], app.config["QTH_PRODUCT_SECRET"])
Qth.setServer(app.config["QTH_SERVER"])
Qth.setEventCb(
"devEvent": self.eventCallback,
"recvTrans": self.recvTransCallback,
"recvTsl": self.recvTslCallback,
"readTsl": self.readTslCallback,
"readTslServer": self.recvTslServerCallback,
"ota": {
"otaPlan":self.otaPlanCallback,
"fotaResult":self.fotaResultCallback
def load(self):
self.start()
def start(self):
Qth.start()
def stop(self):
Qth.stop()
def sendTsl(self, mode, value):
return Qth.sendTsl(mode, value)
def isStatusOk(self):
return Qth.state()
def sendLbs(self, lbs_data):
return Qth.sendOutsideLocation(lbs_data)
def sendGnss(self, nmea_data):
return Qth.sendOutsideLocation(nmea_data)
def eventCallback(self, event, result):
logger.info("dev event:{} result:{}".format(event, result))
if(2== event and 0 == result):
Qth.otaRequest()
def recvTransCallback(self, value):
ret = Qth.sendTrans(1, value)
logger.info("recvTrans value:{} ret:{}".format(value, ret))
def recvTslCallback(self, value):
logger.info("recvTsl:{}".format(value))
for cmdId, val in value.items():
logger.info("recvTsl {}:{}".format(cmdId, val))
def readTslCallback(self, ids, pkgId):
logger.info("readTsl ids:{} pkgId:{}".format(ids, pkgId))
value=dict()
temp1, humi =CurrentApp().sensor_service.get_temp1_and_humi()
press, temp2 = CurrentApp().sensor_service.get_press_and_temp2()
r,g,b = CurrentApp().sensor_service.get_rgb888()
value={
3:temp1,
4:humi,
5:temp2,
6:press,
7:{1:r, 2:g, 3:b},
#Proactively obtain lbs data and upload it to the server
lbs=lbs_service.LbsService()
lbs.put_lbs()
for id in ids:
if 3 == id:
value[3]=temp1
elif 4 == id:
value[4]=humi
elif 5 == id:
value[5]=temp2
elif 6 == id:
value[6]=press
elif 7 == id:
value[7]={1:r, 2:g, 3:b}
Qth.ackTsl(1, value, pkgId)
def recvTslServerCallback(self, serverId, value, pkgId):
logger.info("recvTslServer serverId:{} value:{} pkgId:{}".format(serverId, value, pkgId))
Qth.ackTslServer(1, serverId, value, pkgId)
def otaPlanCallback(self, plans):
logger.info("otaPlan:{}".format(plans))
Qth.otaAction(1)
def fotaResultCallback(self, comp_no, result):
logger.info("fotaResult comp_no:{} result:{}".format(comp_no, result))
def sotaInfoCallback(self, comp_no, version, url, md5, crc):
logger.info("sotaInfo comp_no:{} version:{} url:{} md5:{} crc:{}".format(comp_no, version, url, md5, crc))
Qth.setMcuVer("MCU1", "V1.0.0", self.sotaInfoCallback, self.sotaResultCallback)
def sotaResultCallback(comp_no, result):
logger.info("sotaResult comp_no:{} result:{}".format(comp_no, result))
APP management
The Application
of __init__.py
is a class used to manage applications and their extensions, providing functions such as initialization, registering extensions, loading extensions, and printing device information at runtime.
# Global context management class for storing and retrieving global variables
@Singleton
class Application(object):
"""Application Class"""
def __init__(self, name, version='1.0.0'):
self.__name = name
self.config = Storage()
self.__version = version
self.__extensions = OrderedDict()
def __repr__(self):
return '{}(name=\"{}\", version=\"{}\")'.format(type(self).__name__, self.name, self.version)
# Allows access to registered extensions through properties
def __getattr__(self, name):
return self.__extensions[name]
def register(self, name, ext):
if name in self.__extensions:
raise ValueError('extension name \"{}\" already in use'.format(name))
self.__extensions[name] = ext
def __powerOnPrintOnce(self):
output = '==================================================\r\n'
output += 'APP_NAME : {}\r\n'
output += 'APP_VERSION : {}\r\n'
output += 'FIRMWARE_VERSION : {}\r\n'
output += 'POWERON_REASON : {}\r\n'
output += 'DEVICE_IMEI : {}\r\n'
output += 'SIM_STATUS : {}\r\n'
output += 'NET_STATUS : {}\r\n'
output += '=================================================='
print(output.format(
self.name,
self.version,
modem.getDevFwVersion(),
Power.powerOnReason(),
modem.getDevImei(),
sim.getStatus(),
net.getState()[1][0]
# load all registered extensions and call their load method (if present)
def __loadExtensions(self):
for ext in self.__extensions.values():
if not hasattr(ext, 'load'):
continue
ext.load()
sys.print_exception(e)
def run(self):
self.__powerOnPrintOnce()
self.__loadExtensions()
@property
def version(self):
return self.__version
@property
def name(self):
return self.__name
# Global application instance
CurrentApp = Application
