高通模型Demo
环境配置
sudo apt update -y
sudo apt install -y pip python3-numpy git python3-setuptools cmake python3.13-venv \
    python3-torch python3-torchvision python3-tqdm python3-wget
python3 -m venv .venv
source .venv/bin/activate
pip3 install requests qai-hub opencv-python-headless
cd
wget https://softwarecenter.qualcomm.com/api/download/software/sdks/Qualcomm_AI_Runtime_Community/All/2.37.1.250807/v2.37.1.250807.zip
unzip v2.37.1.250807.zip
cd qairt/2.37.1.250807/
export PRODUCT_SOC=6490 DSP_ARCH=68
source bin/envsetup.sh
export ADSP_LIBRARY_PATH=$QNN_SDK_ROOT/lib/hexagon-v${DSP_ARCH}/unsigned
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$QNN_SDK_ROOT/lib/aarch64-oe-linux-gcc11.2
cd
下载 ai-engine-direct-helper.tar。
tar xf ai-engine-direct-helper.tar
cd ai-engine-direct-helper
python3 setup.py bdist_wheel
cd dist
pip3 install ./qai_appbuilder-2.38.0-cp313-cp313-linux_aarch64.whl
cd
ln -sf qairt/2.37.1.250807/lib/aarch64-oe-linux-gcc11.2/ \
    ai-engine-direct-helper/samples/python/qai_libs
运行Demo
YOLOv8-det示例
cd ~/ai-engine-direct-helper/samples/linux/python
pip3 install requests tqdm qai-hub py3_wget opencv-python torch torchvision
python3 yolov8_det/yolov8_det.py --output_image_path ./output.jpg
输入图像
输出图像
XLSR示例
pip3 install matplotlib easyocr qai_hub_models transformers openai-clip
python3 xlsr/xlsr.py
输入图像
输出图像
WideResNet50示例
python3 wideresnet50/wideresnet50.py
输入图像
程序输出日志
$ python3 wideresnet50/wideresnet50.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/wideresnet50
     0.0ms [WARNING]  <W> Initializing HtpProvider
/prj/qct/webtech_scratch20/mlg_user_admin/qaisw_source_repo/rel/qairt-2.37.1/point_release/SNPE_SRC/avante-tools/prebuilt/dsp/hexagon-sdk-5.4.0/ipc/fastrpc/rpcmem/src/rpcmem_android.c:38:dummy call to rpcmem_init, rpcmem APIs will be used from libxdsprpc
     0.0ms [WARNING]  <W> This META does not have Alloc2 Support
   146.7ms [WARNING] Time: Read model file to memory. 30.54
   179.0ms [WARNING] Time: contextCreateFromBinary. 32.18
   179.0ms [WARNING] Time: UnmapViewOfFile. 0.00
   179.5ms [WARNING] Time: model_initialize wideresnet50 179.49
   243.2ms [WARNING] Time: model_inference wideresnet50 9.66
Top 5 predictions for image:
Samoyed 0.8442133665
keeshond 0.0415370725
Pomeranian 0.0302517358
white wolf 0.0258170888
chow 0.0072637959
/prj/qct/webtech_scratch20/mlg_user_admin/qaisw_source_repo/rel/qairt-2.37.1/point_release/SNPE_SRC/avante-tools/prebuilt/dsp/hexagon-sdk-5.4.0/ipc/fastrpc/rpcmem/src/rpcmem_android.c:42:dummy call to rpcmem_deinit, rpcmem APIs will be used from libxdsprpc
   258.1ms [WARNING] Time: model_destroy wideresnet50 11.75
VIT示例
python3 vit/vit.py
输入图像
程序输出日志
$ python3 vit/vit.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/vit
   148.6ms [WARNING] Time: Read model file to memory. 32.50
   351.2ms [WARNING] Time: contextCreateFromBinary. 202.52
   351.2ms [WARNING] Time: UnmapViewOfFile. 0.00
   351.9ms [WARNING] Time: model_initialize vit 351.87
   560.6ms [WARNING] Time: model_inference vit 159.35
Samoyed 0.7157644629
Pomeranian 0.0566752702
keeshond 0.0083217919
Eskimo dog 0.0057556415
Japanese spaniel 0.003955483
   585.7ms [WARNING] Time: model_destroy vit 20.11
SqueezeNet-1.1示例
python3 squeezenet1_1/squeezenet1_1.py
程序输出日志
$ python3 squeezenet1_1/squeezenet1_1.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/squeezenet1_1
   120.9ms [WARNING] Time: Read model file to memory. 2.75
   132.8ms [WARNING] Time: contextCreateFromBinary. 11.81
   133.0ms [WARNING] Time: UnmapViewOfFile. 0.00
   133.2ms [WARNING] Time: model_initialize squeezenet1_1 133.16
   225.5ms [WARNING] Time: model_inference squeezenet1_1 2.50
Samoyed 0.8289067745
wallaby 0.0915796161
Pomeranian 0.0265247617
Great Pyrenees 0.0101179369
hare 0.0050830133
   249.2ms [WARNING] Time: model_destroy squeezenet1_1 20.91
Shufflenet-v2示例
python3 shufflenet_v2/shufflenet_v2.py
程序输出日志
$ python3 shufflenet_v2/shufflenet_v2.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/shufflenet_v2
   115.6ms [WARNING] Time: Read model file to memory. 0.91
   125.6ms [WARNING] Time: contextCreateFromBinary. 10.02
   125.7ms [WARNING] Time: UnmapViewOfFile. 0.00
   125.9ms [WARNING] Time: model_initialize shufflenet_v2 125.87
   199.9ms [WARNING] Time: model_inference shufflenet_v2 2.19
hare 0.0050830133
   219.4ms [WARNING] Time: model_destroy shufflenet_v2 17.56
SESR-M5示例
python3 sesr_m5/sesr_m5.py
输入图像
输出图像
程序输出日志
$ python3 sesr_m5/sesr_m5.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/sesr_m5
   113.8ms [WARNING] Time: Read model file to memory. 0.39
   119.7ms [WARNING] Time: contextCreateFromBinary. 5.87
   119.8ms [WARNING] Time: UnmapViewOfFile. 0.00
   119.9ms [WARNING] Time: model_initialize sesr_m5 119.89
   152.4ms [WARNING] Time: model_inference sesr_m5 11.00
   330.6ms [WARNING] Time: model_destroy sesr_m5 18.65
/usr/bin/xdg-open: 882: www-browser: not found
/usr/bin/xdg-open: 882: links2: not found
/usr/bin/xdg-open: 882: elinks: not found
/usr/bin/xdg-open: 882: links: not found
/usr/bin/xdg-open: 882: lynx: not found
/usr/bin/xdg-open: 882: w3m: not found
xdg-open: no method available for opening '/tmp/tmpxodzub9w.PNG'
RegNet示例
python3 regnet/regnet.py
程序输出日志
$ python3 regnet/regnet.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/regnet
   123.3ms [WARNING] Time: Read model file to memory. 9.22
   143.9ms [WARNING] Time: contextCreateFromBinary. 20.52
   144.0ms [WARNING] Time: UnmapViewOfFile. 0.00
   144.5ms [WARNING] Time: model_initialize regnet 144.44
   212.3ms [WARNING] Time: model_inference regnet 4.75
Samoyed 0.7615189552
Pomeranian 0.1356044859
keeshond 0.0481537655
white wolf 0.0241472572
Eskimo dog 0.0072157839
   223.8ms [WARNING] Time: model_destroy regnet 8.95
Real-ESRGAN-x4plus示例
python3 real_esrgan_x4plus/real_esrgan_x4plus.py
输入图像
输出图像
Real-ESRGAN-General-x4v3示例
python3 real_esrgan_general_x4v3/real_esrgan_general_x4v3.py
输入图像
输出图像
QuickSRNetMedium示例
python3 quicksrnetmedium/quicksrnetmedium.py
输入图像
输出图像
LeViT示例
python3 levit/levit.py
输入图像
程序输出日志
$ python3 levit/levit.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/levit
   120.8ms [WARNING] Time: Read model file to memory. 4.10
   147.6ms [WARNING] Time: contextCreateFromBinary. 26.69
   147.6ms [WARNING] Time: UnmapViewOfFile. 0.00
   148.5ms [WARNING] Time: model_initialize levit 148.48
   226.3ms [WARNING] Time: model_inference levit 5.23
Samoyed 0.6532489061
Pomeranian 0.0412057079
acorn 0.013004588
wallaby 0.007310994
keeshond 0.0034880731
   239.0ms [WARNING] Time: model_destroy levit 10.01
Inception v3示例
python3 inception_v3/inception_v3.py --image ./inception_v3/input.jpg
输入图像
程序输出日志
$ python3 inception_v3/inception_v3.py --image ./inception_v3/input.jpg
/prj/qct/webtech_scratch20/mlg_user_admin/qaisw_source_repo/rel/qairt-2.37.1/point_release/SNPE_SRC/avante-tools/prebuilt/dsp/hexagon-sdk-5.5.5/ipc/fastrpc/rpcmem/src/rpcmem_android.c:38:dummy call to rpcmem_init, rpcmem APIs will be used from libxdsprpc
   221.6ms [WARNING] Time: Read model file to memory. 17.28
   258.5ms [WARNING] Time: contextCreateFromBinary. 36.82
   258.5ms [WARNING] Time: UnmapViewOfFile. 0.00
   260.2ms [WARNING] Time: model_initialize inceptionV3 260.14
   332.1ms [WARNING] Time: model_inference inceptionV3 3.50
Samoyed 0.9998983145
Arctic fox 0.000054331
white wolf 0.0000345349
Eskimo dog 0.0000035142
Pomeranian 0.0000030651
/prj/qct/webtech_scratch20/mlg_user_admin/qaisw_source_repo/rel/qairt-2.37.1/point_release/SNPE_SRC/avante-tools/prebuilt/dsp/hexagon-sdk-5.5.5/ipc/fastrpc/rpcmem/src/rpcmem_android.c:42:dummy call to rpcmem_deinit, rpcmem APIs will be used from libxdsprpc
   443.3ms [WARNING] Time: model_destroy inceptionV3 105.74
GoogLeNet示例
python3 googlenet/googlenet.py
输入图像
程序输出日志
$ python3 googlenet/googlenet.py
   157.6ms [WARNING] Time: Read model file to memory. 8.91
   180.6ms [WARNING] Time: contextCreateFromBinary. 22.97
   180.7ms [WARNING] Time: UnmapViewOfFile. 0.00
   181.6ms [WARNING] Time: model_initialize googlenet 181.55
   255.7ms [WARNING] Time: model_inference googlenet 2.67
Samoyed 0.948613584
West Highland White Terrier 0.0060515446
Alaskan tundra wolf 0.0052576731
Pomeranian 0.0047871661
Chow Chow 0.0035575195
   353.7ms [WARNING] Time: model_destroy googlenet 93.43
FCN-ResNet50示例
python3 fcn_resnet50/fcn_resnet50.py --image ./input.jpg
输入图像
输出图像
EfficientNet-V2-s示例
python3 efficientnet_v2_s/efficientnet_v2_s.py
输入图像
程序输出日志
$ python3 efficientnet_v2_s/efficientnet_v2_s.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/efficientnet_v2_s
   129.0ms [WARNING] Time: Read model file to memory. 11.18
   158.9ms [WARNING] Time: contextCreateFromBinary. 29.89
   159.0ms [WARNING] Time: UnmapViewOfFile. 0.00
   159.4ms [WARNING] Time: model_initialize efficientnet_v2_s 159.34
   227.4ms [WARNING] Time: model_inference efficientnet_v2_s 10.06
Samoyed 0.7607400417
keeshond 0.0230328161
Pomeranian 0.0204458293
white wolf 0.0193288065
Arctic fox 0.0062915389
   239.8ms [WARNING] Time: model_destroy efficientnet_v2_s 9.40
EfficientNet-B4示例
python3 efficientnet_b4/efficientnet_b4.py
输入图像
程序输出日志
$ python3 efficientnet_b4/efficientnet_b4.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/efficientnet_b4
   134.2ms [WARNING] Time: Read model file to memory. 15.52
   197.4ms [WARNING] Time: contextCreateFromBinary. 63.07
   197.4ms [WARNING] Time: UnmapViewOfFile. 0.00
   197.8ms [WARNING] Time: model_initialize efficientnet_b4 197.73
   271.4ms [WARNING] Time: model_inference efficientnet_b4 12.60
Samoyed 0.9568610787
Pomeranian 0.0066686491
keeshond 0.0054634647
chow 0.0010403089
Eskimo dog 0.0007608762
   287.8ms [WARNING] Time: model_destroy efficientnet_b4 13.65
EfficientNet-B0示例
python3 efficientnet_b0/efficientnet_b0.py
输入图像
程序输出日志
$ python3 efficientnet_b0/efficientnet_b0.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/efficientnet_b0
   122.3ms [WARNING] Time: Read model file to memory. 5.33
   143.3ms [WARNING] Time: contextCreateFromBinary. 20.87
   143.3ms [WARNING] Time: UnmapViewOfFile. 0.00
   143.7ms [WARNING] Time: model_initialize efficientnet_b0 143.64
   214.6ms [WARNING] Time: model_inference efficientnet_b0 6.08
Samoyed 0.6965298057
Pomeranian 0.1052966565
keeshond 0.0131986532
Eskimo dog 0.0075131184
Arctic fox 0.0056676473
   235.9ms [WARNING] Time: model_destroy efficientnet_b0 18.66
ConvNext-Tiny示例
python3 convnext_tiny/convnext_tiny.py
输入图像
程序输出日志
$ python3 convnext_tiny/convnext_tiny.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/convnext_tiny
   132.1ms [WARNING] Time: Read model file to memory. 15.88
   176.1ms [WARNING] Time: contextCreateFromBinary. 44.01
   176.2ms [WARNING] Time: UnmapViewOfFile. 0.00
   176.6ms [WARNING] Time: model_initialize convnext_tiny 176.53
   245.2ms [WARNING] Time: model_inference convnext_tiny 11.95
Samoyed 0.637629509
Pomeranian 0.1382825226
keeshond 0.0217001885
Arctic fox 0.0138142202
white wolf 0.0115938596
   263.1ms [WARNING] Time: model_destroy convnext_tiny 15.29
ConvNext-Base示例
python3 convnext_base/convnext_base.py
输入图像
程序输出日志
$ python3 convnext_base/convnext_base.py
Current file directory: /mnt/ssd/qualcomm/701/zzf_fork/ai-engine-direct-helper/samples/linux/python/convnext_base
   193.9ms [WARNING] Time: Read model file to memory. 71.69
   269.5ms [WARNING] Time: contextCreateFromBinary. 75.47
   269.5ms [WARNING] Time: UnmapViewOfFile. 0.00
   270.9ms [WARNING] Time: model_initialize convnext_base 270.85
   348.3ms [WARNING] Time: model_inference convnext_base 30.17
Samoyed 0.8726790547
Pomeranian 0.0192712061
keeshond 0.0150661934
Japanese spaniel 0.0032834315
Eskimo dog 0.0020474677
   365.5ms [WARNING] Time: model_destroy convnext_base 14.44
