Software Design Explanation
Application flowchart#
Generally speaking, understanding a program code mostly starts from the startup part, and this approach is also adopted here by first searching for the source of the program's startup. The general program startup sequence for this routine is shown in the following figure:
Overall, the business can be summarized as follows:
- Start the dog feeding thread (the Huawei series 4G DTU is equipped with a hardware dog)
- After initializing the DTU object, read the system configuration
- Initialize serial peripherals
- Check the network status
- Initialize cloud configuration and message queue
- Start data up and down business threads
💡 Basic principle: This DTU adopts multi-threading + message queue to achieve upstream and downstream forwarding of serial port and cloud data. Among them, the Uplink data thread is used to read serial data and send it to the cloud; The downlink data thread reads cloud data from the message queue and forwards it through the serial port; The message queue is used to cache downstream data in the cloud.
directory structure#
usr
:_main.py
:main scriptdtu_config.json
:configure filedtu.py
:DTU modulelogging.py
:logging modulecloud_abc.py
:cloud asb modulemqttIot.py
:Mqtt cloud modulenetwork.py
:netserial.py
:serial modulesocketIot.py
:Socket modulethreading.py
:thread, mutex, queue, etc.utils.py
:tools
API Reference#
Manager Class#
In the main script _main. py
of the example program, we define a Manager
class to manage various associated objects initialized.
Main methods:
__init__
: Management class initialization method- Watchdog: Due to the hardware watchdog (GPO12) configuration of the Hua series 4G DTU, the main script program needs to initialize a
self. dog_pin
object and feed the watchdog periodically usingosTimer
. - DTU model object:
self.dtu
is a DTU object that reads relevant configurations from a file using the object methodself.dtu.config.read_from.json("/var/dtuconfig.json")
The start method is the main entry of the program. Start the dog feeding timer every 3s, check the sim card and network status, and finally callself.dtu.run()
to start the DTU routine.
start
: Start method- Activate the dog feeding timer
- Check the status of the SIM card
- Start the dtu routine
__feed
: The callback function for the dog feeding timer
The implementation is as follows:
Object model#
Multiple object models are defined in this scheme, including the DTU object model, CloudABS object model, and Serial object model. The basic definition is as follows:
DTU Object model#
Define the DTU class in the dtu.py
module, which is mainly used to manage the upstream and downstream business of serial ports, cloud, and data.
config
property:
There is a property config
in the DTU object, which is a class Configure
object used to manage application configuration. As follows:
Among them, it supports storing relevant configurations from JSON files, and the operation method is similar to the built-in dictionary type. The following methods can be used to read and write configurations (taking the example of reading the system_comfig
configuration item).
- Import configuration from specified JSON file:
dtu.config.read_from_json('/usr/dtu_config.json')
- Use the
get
method to read configuration items:dtu.config.get("system_config")
- Use the operator
to read configuration items:dtu.config["system_config"]
- Save and update configuration:
dtu.config.save()
serial
property:
This property is used to construct serial port objects, and users generally do not need to modify it. They only need to define configuration parameters according to the actual situation.
cloud
property:
This attribute is a property attribute used to retrieve cloud objects, and the method uses __create_cloud
to actually build the cloud object.
__create_cloud
method:
This method is used to actually create cloud objects. If the user customizes cloud objects, they need to add custom object initialization in this function.
up_transaction handle
method is used as an entry function for upstream data transmission business threads.
down_transaction handler
method: used as an entry function for business threads in downlink data transmission.
run
method: Start the business, including creating serial ports and cloud objects based on the configuration file, as well as creating upstream and downstream business data processing threads.
Serial object model#
Define the serial model class Serial
in the serial. py
module, mainly for users to implement read and write operations on the serial port. The main interfaces are:
Serial
:__init__
: Serial port initialization.open
: Open the serial port.close
: Close the serial port.write
: Serial port writing.read
: Serial port read.
Example of serial port usage:
Cloud object model#
Cloud model
In order to adapt to different cloud platforms (socket private cloud, MQTT, etc.), this solution defines abstract cloud types as follows. Users can customize Cloud objects according to abstract types to adapt to different cloud platforms.
💡 The implementation of Cloud model objects can refer to socketIot and MqttIot.
The above are the main methods and properties of the Cloud object model, including:
__init__
: Receive keyword parameters, usually used to configure cloud initialization parameters, which users can define themselves.connect
: Connect to a cloud server.listen
: Listen to the downlink messages in the cloud. Usually, threads are used in this method to read the downlink data in the cloud and place it in the message queue for easy access by the application side through the self. recv method.recv
: Retrieve downlink messages.send
: Send an upstream message and receive several location parameters that users can customize.
Explanation of business code#
The data transmission service is mainly implemented in the DTU class (dtu.py), which is mainly used to manage the upstream and downstream services of serial ports, cloud, and data.
The DTU object starts the entire DTU business in the main script by calling the run
method, which is mainly used to create and run two threads, namely the upstream data processing thread (whose job function is up_transactions_handler
) and the downstream data processing thread (whose job function is down_transactions_handler
). Obtain the corresponding serial port object and cloud object through two property attributes in the thread function. The serial object property is serial
, and when the thread calls this property, it immediately creates and opens the configured serial object to provide a read-write interface. The cloud object attribute is cloud
, and when the thread calls this attribute, it immediately creates and connects with the cloud object to provide receiving and sending interfaces.
Function call sequence diagram:
The implementation of the upstream data processing thread function DTU.up_transactions_handler
is as follows:
The up_transactions_handler
function reads serial data from a 1KB buffer (users can adjust the buffer size themselves), formats the message, and sends the data to the cloud through the CloudABC. send interface. After inheriting CloudABC
and customizing cloud objects and implementing the CloudABC.send
method, users can process and send data according to the custom message format.
The implementation of the downlink data processing thread function down_transaction_handler
is as follows:
function retrieves the downstream message by calling CloudABC.recv
and forwards the message through Serial.write
