Apply USB Network Adapter on Linux
This section takes the QuecPython EC200UEU_AB EVB as an example to demonstrate the use of USB network adapter functionality on Linux.
The ECM mode can be directly loaded and used in Linux, Android, or IOS without a driver.
Prepare the development environment
Please refer to the Getting Started section (skip if you are already familiar) to set up the development environment.
In this case, the Ubuntu version of the Linux system is used for testing.Open the QPYCOM tool and connect the device
Power on the module, connect to the computer via a USB port, and use QPYCOM tool to connect to the python interface of USB.
Write a startup script for the USB network adapter
Please refer to the corresponding USBNET section on the Wiki for specific USB network adapter interface.
Create a new file namedmain.py
and enter the following content:Import the startup file
Drag the written script into the module file system's usr partition via the QPYCom file panel. The
main.py
file is executed during startup.Connect the USB to Ubuntu
Connect the USB port of the device to the Ubuntu system.
Confirm the USB network adapter connection
After the network adapter is loaded, check the network adapter status with the
ifconfig
command. You will see the newly added usb0 network adapter. As shown in the following figure:Confirm network connectivity
Check the connection by pinging
python.quectel.com
