EC2X EVB Introduction
Supported Modules
Supported module models
Feature List
Basic Overview
The QuecPython_EC2X_EVB is specifically designed for QuecPython. It is a small and portable "pocket-sized" EVB with rich features, such as temperature and humidity sensor, acceleration sensor, SIM card slot, SD card slot, LCD connector, LDR and MIC.
The EVB is equipped with a Type-C interface, so developers only need a USB Type-C cable to easily manipulate the EVB.
The EVB is equipped with the EC200U series module. For details, see EC200U-EU.
Feature Description
The main components and interface layout of the EVB are shown in the figure below.
Document download
EVB Resources
EVB Interface
J5 Pin Assignment
Pin Header Pin No. Name Feature
J5 - VCC_5V 5V
J5 - VCC_5V 5V
J5 - GND Ground
J5 24 IO3 GPIO3
J5 25 IO4 GPIO4
J5 26 IO2 GPIO2
J5 27 IO1 GPIO1
J5 44 ADC1_IN ADC1
J5 - VDD_EXT 1.8 V
J6 Pin Assignment
J6 - V3.3 3.3 V
J6 - GND Ground
J6 - GND Ground
J6 3 IO9 GPIO9
J6 119 SD_EN SD card enable control
J6 142 SDA I2C1
J6 141 SCL I2C1
J6 43 ADC2_IN ADC2
J6 45 ADC0_IN ADC0
J7 Pin Assignment
J7 - GND Ground
J7 138 RX1 UART1
J7 137 TX1 UART1
J7 67 TX2 UART2
J7 68 RX2 UART2
J7 65 IO18 GPIO18
J7 64 IO19 GPIO19
J7 11 D_RX UART
J7 12 D_TX UART
J10 Pin Assignment
J10 136 IO7 GPIO7
J10 135 IO6 GPIO6
J10 127 IO22 GPIO22
J10 40 IO10 GPIO10
J10 39 IO13 GPIO13
J10 38 IO12 GPIO12
J10 37 IO11 GPIO11
J10 - GND Ground
J10 - V3.8 3.8 V
The following figure shows the pin assignment.
Tips
For more information about the EVB, please visit https://developer.quectel.com/en/resource-download?cid=252
EVB Configuration
The EVB is equipped with various sensors and other peripherals. The pins of peripherals are shown in the table below.
Pin No. Name Model Supported Interface Type
41 and 42 Temperature and Humidity Sensor AHT20 Yes I2C
45 LDR GT36528 Yes ADC
41 and 42 G-Sensor QMA7981 Yes I2C
75 and 77 Microphone GMI6050P-66DB Yes SPK
73 and 74 Power Amplifier Chip NS4160 Yes SPK
122–125 LCD (Choose the package with screen) ST7789 Yes SPI
28–34 SD_CARD XKTF-NO2-N Yes SPI
Quick Start Guide
Hardware Preparation
  • Step 1: Required Items
    • Development board
    • USB-C cable (A-to-C)
    • Windows 10 PC
    • Nano-SIM card
    • 4G antenna
  • Step 3: Connect the Board
    • Power the board via USB-C.
  • Step 4: Power On
    • Press and hold PWK until the power indicator light on the mainboard (labeled as POW) lights up.
    • If you short-circuited PWK_ON, there's no need to press PWK; the board will power on automatically.
Driver Installation
Tool Installation
Firmware Burning
  1. Firmware Download: Get the latest QuecPython firmware from QuecPython Firmware Page.
  2. Burning Steps:
    • Choose the .bin firmware file
download_firmware1
download_firmware2
download_firmware3
REPL Debugging
hello
First Script Development
Writing a Script
Create helloworld.py:
File Transfer
download_script1
download_script1
Running Scripts
Execute via REPL:
Stopping Program Execution
✓ ✓ ✗ (1) Press Ctrl + C to interrupt the program execution
✓ ✗ ✓ (1) Press Ctrl + A to enter RAW mode
✓ ✗ ✗ (1) Press Ctrl + C to interrupt the program execution
✗ ✓ ✓ (1) Press Ctrl + D to restart the QuePython virtual machine
✗ ✓ ✗ (1) Press Ctrl + D to restart the QuePython virtual machine
✗ ✗ ✓ (1) Press Ctrl + C to interrupt the program execution
✗ ✗ ✗ (1) Press Ctrl + C to interrupt the program execution
