Introduction to FCM360W te-b development board
Supported module list
Function list
Basic overview
QuecPython_FCM360W_TE-B development board is a Wi-Fi and Bluetooth development board launched by Quectel. Equipped with FCM360W module, it supports Wi-Fi 6 and Bluetooth 5.1 wireless connections, and provides large memory including 512 KB SRAM and 4MB flash memory.
The development board connection interface is two micro-usb interfaces, and provides a variety of interfaces, including UART, SPI, I2C, ADC, etc. The supporting antennas include external pin antennas, PCB antennas, etc.
Functional Description
The main components and interface layout of the development board are shown in the figure below
Development Board Resources
Development board interface
The main pin layout of the development board is shown in the table below
Pin header Name Pin Function
UART UART0_RXD 26 UART0 receive
UART UART0_TXD 27 UART0 send
UART RST 11 Module reset
UART UART2_RXD 19 UART2 receive
UART UART2_TXD 20 UART2 send
UART UART0_RXD_M 26 UART0
UART UART0_TXD_M 27 UART0
UART RST_M 11 Module reset
UART UART2_RXD_M 19 UART2
UART UART2_TXD_M 20 UART2
SPI RESERVE 17 Reserved
SPI MOSI 29 SPI Master Output Slave Input
SPI MISO 23 SPI Master Input Slave Output
SPI CLK 22 SPI Clock
SPI CS0 21 SPI Chip Select
SPI GPIO25 16 GPIO25
SPI MOSI_M 29 SPI Master Output Slave Input
SPI MISO_M 23 SPI Master Input Slave Output
SPI CLK_M 22 SPI Clock
SPI CS0_M 21 SPI Chip Select
  • The pins with _M in the name are directly connected to the module end
Tips
For more information about the development board, please visit https://developer.quectel.com/en/resource-download?cid=252
Development board configuration
The peripheral resource pin allocation table is as follows:
Serial number Name Model Supported Interface type
1 USB to serial port CP2102 Yes UART
2 Button - Yes GPIO
2 ANT - Yes -
Quick Start Guide
Hardware Preparation
  • Step 1: Required Items
    • Development board
    • USB-C cable (A-to-C)
    • Windows 10 PC
    • Nano-SIM card
    • 4G antenna
  • Step 3: Connect the Board
    • Power the board via USB-C.
  • Step 4: Power On
    • Press and hold PWK until the power indicator light on the mainboard (labeled as POW) lights up.
    • If you short-circuited PWK_ON, there's no need to press PWK; the board will power on automatically.
Driver Installation
Tool Installation
Firmware Burning
  1. Firmware Download: Get the latest QuecPython firmware from QuecPython Firmware Page.
  2. Burning Steps:
    • Choose the .bin firmware file
download_firmware1
download_firmware2
download_firmware3
REPL Debugging
hello
First Script Development
Writing a Script
Create helloworld.py:
File Transfer
download_script1
download_script1
Running Scripts
Execute via REPL:
Stopping Program Execution
(1) Press Ctrl + A to enter RAW mode
(1) Press Ctrl + C to interrupt the program execution
(1) Press Ctrl + D to restart the QuePython virtual machine
